intake manifold
Old Aug 21, 2010 | 04:06 PM
Primerftw's Avatar
Default intake manifold
I have a 1991 accord lx f22a1 and i was wondering if the H23 intake manifold works on this motor?
Old Aug 21, 2010 | 09:29 PM
g22cd5's Avatar
Supper Moderator
yes it bolts right up. You need to hook up the IAB's aka "black box" to a vacuum source. SO when at certain rpm the 2nd set of runners are opened by the butterflies for your added high end air flow. OR you can modify the intake manifold and remove the butterfly set up and have a high flowing intakmanifold
Old Aug 21, 2010 | 10:31 PM
Primerftw's Avatar
sweet well i got everything off of it including injectors so should i just use all the parts off my manifold?.....and i scored all of this for 40 bucks ha
Old Aug 22, 2010 | 12:03 AM
g22cd5's Avatar
Supper Moderator
Did you get the black box with it too?
That’s not bad of a deal! If I remember correct the h23 and f22 injectors are the same. But if you wanna be 100% sure use your f22 injectors. What exhaust manifold are you using?
Old Aug 26, 2010 | 07:36 PM
Primerftw's Avatar
I got the black box but im not going to use the butterflies i have a bisimoto header comin soo and hondata but i didnt get the thermostat housing off of this motor and i think i need it..
Old Aug 26, 2010 | 07:43 PM
g22cd5's Avatar
Supper Moderator
I'm not using my butterflies on my h22 intake manifold either. Are you going to port it out yourself? It's really easy just need to cut and dremel some. Opens up the manifold for much much better air flow.
Old Aug 26, 2010 | 07:51 PM
Primerftw's Avatar
yeah i have a dremel explain lol
Old Aug 26, 2010 | 08:01 PM
g22cd5's Avatar
Supper Moderator
Well I used a heavy duty hacksaw and like 6 or 7 blades but this is what mine looks like so far. I just need to get a dremel with a diamond bit to finnish the job.
Old Aug 26, 2010 | 08:02 PM
Primerftw's Avatar
oh i though about doing that but idk
Old Aug 27, 2010 | 12:16 PM
g22cd5's Avatar
Supper Moderator
Easy and cheap power mod...After porting like I did the manifold will flow as good as the Skunk 2 h22 manifold for $300 cheaper. Takes only couple hrs if you have all the tools. I just haven’t finished mine cus I'm missing some tools that I need to get. But I'm not in a hurry cus the manifold won’t be bolted up to the head for few more months. Also I don't feel like buying a dremel so I'm gonna buy a diamond bit cutting drill bit and then sand it smooth after that. Total cost me will be like 30bucks or so...that's 300% cheaper than the Skunk 2 manifold.
