F22/H23 interchangable parts
Old Aug 22, 2010 | 10:21 PM
Hgpaperstacks's Avatar
Question F22/H23 interchangable parts
hi i have a few ?s about parts that can be used from the H23 and bolt on the F22. can u guys tell me what parts will bolt on to my F22 engine, how it will effect it and what kinda gains if any. thanks n advance. g22c5 it would be great if u could offer any input. i want 2 upgrade my motor but dont have enuff for a full swap just yet.
Old Aug 23, 2010 | 08:51 AM
g22cd5's Avatar
Supper Moderator
1st off what gen and trim accord do you have? If you can find a h23 head that is fully swappable. If you don't want a head swap then you can use h23 intake manifold and it will bolt right up. But you have to make sure you have the "black box" to control the butterflies for your high end air flow. The f22 and h23 exhaust manifolds are the same. But if you have the f22a1 you can swap for the f22a4 exhaust manifold and gain couple ponies. You can also get the f22a6 cam shaft and ECU. The f22a6 cam is more aggressive then the f22a1/4. But make sure you grab the ECU it is a must.
Now if you have the f22bx engines then NONE of the h23 parts will swap over. Thos heads suck big time. Crappie flow and SOHC vtec is performance pointless.
But I need to know what gen and trim accord you have to really tell you what all can be done to add some more power by using stock parts. Please put that in your sig or right under your name like mine "1993 accord"
Old Aug 23, 2010 | 08:21 PM
i have a 1993 4 door lx and also a 1993 2 door. Both engines are stock F22s but i dont know what kind. (1st time modding a honda engine) You mentioned a head swap(what would it improve?) and what else can i swap? Thanks
Old Aug 23, 2010 | 09:18 PM
ebarrera661's Avatar
Almost A Senior Member
So I am Screwed with my f22b2 lol
Old Aug 23, 2010 | 11:31 PM
g22cd5's Avatar
Supper Moderator
what trim accord did they come out of?? ex lx dx?
you can also tell the engine code stamp on the block...
h23 head flows better in stock forum than the f22. that and it also has the better intake manifold
here is a pic to show you where the engine code stamp is...its located to the left of your header where the engine and tranny just about meet
Attached Thumbnails F22/H23 interchangable parts-h22-4-.jpg
Old Aug 23, 2010 | 11:33 PM
g22cd5's Avatar
Supper Moderator
do a head swap and you will be fine. h23 head works well w/o swapping pistons. h22 head you will need to swap for higher c/r pistons to use vtec.
Or you can swap for a f22a head since it's a much much better head than any of the f22bx heads
Old Aug 24, 2010 | 12:12 AM
Both of my slabs(cars) are lx models.
Old Aug 24, 2010 | 12:21 AM
g22cd5's Avatar
Supper Moderator
so both of your cars have the same engine the f22a1. The lowest HP f22 engine PGFI engine they make..lol
At that point you can use the h23 intake manifold with the f22a6 cam and ecu with the f22a4 header and you will be around 160 maybe 170 with good intake exhaust. But I strongly recommend getting at least a street tune. Then you can pull out prob. 180hp. Which is really GOOD power for a single slammer f22
Old Aug 24, 2010 | 12:29 AM
Hellz yea..ok im wondering what should i do 2 my trannys(both automatics) 2 hold more power and how can i get that 2 the wheels?
Old Aug 24, 2010 | 12:34 AM
g22cd5's Avatar
Supper Moderator
don’t do a thing to the auto trans. Swap them out for h22 or h23 5speed trans. When you start adding more power over stock your tranny won't like it and will fail out very very soon. So you best bet if for the 5 speed swap.
