NEW QUESTION...Oil Puddle Under Engine?
Old Sep 22, 2004 | 03:42 AM
Default NEW QUESTION...Oil Puddle Under Engine?
There are four main answers for this question...
You look under your Honda and you see a puddle of oil spreading outward...what do you think may have happened..
There are four good answers to this one...
WheelBrokerAng[8D]
[IMG]local://upfiles/22/A954FA5BD5F24DE08FEC5EF2FBF5D43A.jpg[/IMG]
Old Sep 22, 2004 | 02:42 PM
6thgen's Avatar
Default RE: NEW QUESTION...Oil Puddle Under Engine?
A gasket somewhere is blown or leaking?
Old Sep 23, 2004 | 03:26 AM
Congrates...
You got a part of one of the four answers..
This one would be correct. Your answer finished out with this here answer..Your oil pan gasket /or oil pan drain bolt washer may be leaking..
Now we need answers #2, #3 and #4...comon guys and gals lets play with this...these are good learning experiances for everyone.
Thanks for your answer 6thGen..
WheelBrokerAng[sm=icon_cheers.gif]
Old Sep 26, 2004 | 05:41 PM
maxst2
Seal blown
Old Oct 5, 2004 | 11:14 AM
6thgen's Avatar
Oil filter leaking or not seated or sealed?
Old Oct 7, 2004 | 02:37 AM
Yes, there's another correct answer...Maxst2 hhoooraayyy for Max
Here is another answer for my own question...
** Oil Prssure Sending Unit (switch) leaking, this is one of the main causes of the Puddle Of Oil under Car Thingy.....
And 6th Gen was close on the 4th answer...it is that your engine oil seals are leaking...something else to watch out for is when you pull a plug and its getting a load of oil on it...This is caused by a leaking $2.19 cent seal
Later..WheelBrokerAng[8D]
Old Nov 20, 2004 | 12:07 AM
poff1986's Avatar
could also be a stipped oil pan..although i doubt youd have a huge puddle unless u leave it sit for a while..
Old Dec 17, 2004 | 03:09 PM
ElectricTwilight
I'm throwing in my vote for the oil pan gasket...all 3 accords i've owned have had bad gaskets..
Old Apr 14, 2009 | 08:12 PM
status's Avatar
good info.
rics06
Jun 12, 2013 07:11 AM
rics06
Jun 4, 2013 04:44 PM
oneloudskunk
Nov 29, 2010 07:06 PM
pr1286
Aug 22, 2010 01:22 PM
maro
Aug 16, 2008 12:09 PM
