f22b turbo
Old Jun 21, 2006 | 03:45 AM
absolutalchemy's Avatar
Default f22b turbo
does anyone know what exactly i would need to set up a turbo on a 1997 accord 2.2 L SOHC VTEC motor or if there is motor i can swap a turbo set up from ... ive been looking but i can only find kits for a few thousand and i really cant afford it ... thanks
Old Jun 21, 2006 | 04:50 AM
Default RE: f22b turbo
yes i do... your going to need at least 13-1500 though. heres a short list, there are other things youll need
manifold
turbo
wastegate
bov
fmu
missing link
intercooler
piping
Old Jun 21, 2006 | 10:19 AM
mbo1985's Avatar
This is a list of all the stuff I used. I posted it way back here on the turbo help!!! post after I installed my turbo. All stuff off ebay unless otherwise noted.
T3/T4 Garrett Wheel Hybrid .63 (new in box off ebay for 256 bucks)
F22B Log style manifold from f22parts.com (was warped when I bought it. May want to look somewhere else before dropping the 300-400 bucks on it).
HKS 38mm external wastegate
Raptor style BOV
Prelude intake pipe kit with BOV flange welded in. (I haven't seen this on ebay recently, but it bolted right up. Just had to get rid of washer fluid tank). Came with all hardware!
Vortech 12:1 FMU
Walbro 255 Intank fuel pump
Godspeed front mount intercooler
MSD Boost Timing Master (jegs.com)
Steel oil line and fittings
Oil drain kit
K&N Air Filter (Advance Auto)
Vacuum line, bolts, clamps, etc (Advance Auto)
Autometer boost guage and air/fuel ratio gauge
Downpipe was used from someone with one for a 97 accord ex. I had to cut off the flange and re-weld it at a different angle. Also had to add o2 bungs. I recommend either getting one from a kit (like drag), or finding a used one like i did and modding it for your use. Otherwise, take it to an exhaust shop. You can even piece together a mock downpipe in PVC and take it to the shop to actually fabricate.
Looks like i forgot to throw missing link in there. That is a VERY important part.
cortzeigler
Jul 30, 2012 01:58 PM
streetcustoms
Nov 1, 2007 11:31 AM
wjmj
Jan 7, 2007 10:57 AM
djarmysgt
Dec 13, 2006 12:36 AM
Accordn2dis
Sep 5, 2006 11:40 PM
