Sunroof Switch...
Old Jun 22, 2006 | 04:13 PM
xxxcoojaxxx's Avatar
Default Sunroof Switch...
I was wondering if any knows how to change the bulb for the moonroof/sunroof switch that lights up at nigh on a 2005 Honda Accord EX? My doesn't light up anymore. I heard it was fairly simple, but still someone else said you had to take the dash out so I don't know. Thank you.
Old Jun 29, 2006 | 12:07 PM
Default RE: Sunroof Switch...
ORIGINAL: xxxcoojaxxx
to be honest with you i have never replaced just the bulb...
pry out the switch, look on the back side, if the switch has its own bulb , it should be fairly easy to remove and replace ..
But car is still under warranty unless you got over 36k miles.. So why not have the dealer deal with it..
Old Jun 30, 2006 | 12:02 AM
YeuEmMaiMai's Avatar
remove switch using flat scewdriver with tape on the blade. Bulb is on the side and is about 1/4 wide. you twist it to remove it and you can get a new one at the dealer.
Matthew Kniss
Jun 30, 2014 06:00 PM
jam
Oct 24, 2013 08:11 PM
funkyguy
May 16, 2012 11:22 AM
HondagalGA
Sep 13, 2006 09:34 PM
jayem722
Nov 18, 2005 07:06 PM
