Reset ECU
Old Jun 23, 2006 | 07:03 AM
Zambo's Avatar
Default Reset ECU
How do i reset my ECU would the best way to just take the battery terminal off or what or is their a propper reset switch ? Just out of curiosity cause i know a mate with a magna an he had to do it when he put his exausht and Cold Air Intake on?
Zambo
Old Jun 23, 2006 | 01:36 PM
Default RE: Reset ECU
I've always been under the impression that just pulling the negative battery terminal will do it...
Old Jun 23, 2006 | 06:18 PM
Zambo's Avatar
Same Here Thankyou ill give it ago
Old Jun 23, 2006 | 10:20 PM
mbo1985's Avatar
For future reference, you can just pull the battery back up fuse (7.5 amp) for a minute or so. It's good for when you don't have tools at hand.
Old Aug 13, 2006 | 02:40 AM
9JordonFlex9's Avatar
Simple enough, hopefully you see this....
This is how you do it...lil more than just pullin the negative off
Disconnect the negative battery part(whatever the tech term is...) , let it sit for at least 30 seconds...you can let it sit as long as you want, do so...I let mine sit for at least a decent 10minutes, overnight is good....
Turn on the car, let it run for 5-10minutes, dont touch the gas at all. (or whenever the fans turn on to cool the engine....)
Turn off the car.
Run it as you like then.
After you turn it off, if you have modifications, do it with each one so the ECU can adapt to each one....they suggest to do it with each weather change.....fall, winter, spring, summer, easy nuff
This can never hurt your ECU, most Honda dealerships do this when you bring it in for tune ups and whatnot
Dont reset ecu if ur running a different type of gas, or gas additives.
Hint-You can also(while the negative is off the battery) step on the brake for 10 seconds to help make sure the ECU is cleared and memory is cleared for the next turn of the key.
Also! If you do have mods, some people run it hard to get used to pushing itself to the limit, a good 3 runs, 1st through 3rd some people.
Hope that helps you out to the fullest
toicy4ya
Aug 6, 2008 05:28 PM
Honda_Dude
Nov 5, 2007 05:28 PM
punyeta
Aug 29, 2006 02:40 AM
darryltravis
Apr 25, 2006 09:23 PM
HondaLawgik
Apr 16, 2006 04:19 AM
