DRL FIX .. by ECKHART
Old Jun 24, 2006 | 05:34 AM
Default DRL FIX .. by ECKHART
On behalf of HAF,,, i would like to tank ECKHART. for writing up this post...I am sure it will help someone ..
FROM ECKHART...
Hi, I'm hoping you can post this great fix for a typical 92 (to 02) daytime running light fix (Might be for Canada cars only).
My symptoms were:
DRL light on all the time. Even when emergency brake was released.
When hi beams would be turned on the passenger side hi beam did not work.
Replaced all 4 bulbs and no change.
Found an article that the problem may be the DRL Relay. I followed the instructions and fixed it. It is as simple as removing the module, taking the circuit board out and re-soldering the joints.
Here is the article, with pictures:
http://www.nyx.net/~smanley/hondadrlfix/index.html
slippynuxx
Aug 17, 2023 02:44 PM
zann121
Jun 23, 2009 06:26 PM
eckhart
May 28, 2009 05:43 PM
surajsss
Sep 14, 2007 08:37 AM
eckhart
May 27, 2006 07:40 PM
