Headlight Adjustment 95 Accord
Old Jun 27, 2006 | 03:15 PM
Salamander1
Default Headlight Adjustment 95 Accord
Hello All:
What would be the best tool to adjust stock headlights? I have tried several flathead screwdrivers as well as two phillips. Does anyone have any tips on what you use or what a handy little tool is for this job?
http://img388.imageshack.us/img388/6...dlight23yv.jpg
Thank you in Advance!
Old Jun 27, 2006 | 03:50 PM
Default RE: Headlight Adjustment 95 Accord
what type of slot does it have? I can't see the slotting from the picture but if a flathead won't work and a phillips won't work then is it a special type that you can see? If you can get a slightly better picture I could tell you a more exact answer....
Old Jun 27, 2006 | 07:04 PM
Salamander1
I don't have a picture of the slot, as it is a little hard to see. When looking at it however, you can tell there is a small star shaped cog that you have to move left or right to move the headlight horizontally.
Please excuse this STUPID picture, but this is kinda what it looks like:
http://img474.imageshack.us/img474/6...ignment1zz.jpg
Old Jun 27, 2006 | 10:32 PM
all that i have ever used is a long blade phillip screwdriver
Old Jun 28, 2006 | 03:01 PM
Salamander1
Ok, after talking with the dealers ("huh what are you talking about, you probably don't know what your doing."), I have concluded that either this isn't a common process or there are no special tools to preform this task.
With that being said, I found a way to accomplish the same goal; although a little more time consuming.
Process:
1. Remove the three LONG screws that hold on the horizontal white protective cover over the alignment screw. (This cover is on the back of the High Beam section)
2. manually rotate the wheel left and right to achieve desired location.
3. Drive around to make sure my lights are not all over the place.
4. Make modifications
5. Drive around some more
6. Reinstall the white cover
I found out why I was unable to move the screw with a flathead was because the alignment screw was rusted and needed a little shot of WD-40.
Thank you all for your comments!
Old Jun 28, 2006 | 03:21 PM
you can also adjust them by aiming the headlights at a wall. Park about 6 feet back and aim at the wall, you want your headlights beam to be center at a point approx. 3 feet up (if memory serves...) and facing straight forward. That's one of the easiest ways... Glad you got it fixed though!
kappakid
Jul 28, 2011 07:06 AM
skingjack
Aug 24, 2010 08:45 PM
GN517
Dec 9, 2009 05:36 PM
slow1500
Mar 18, 2009 07:47 PM
avulan
Dec 19, 2006 11:04 PM
