Battery corrosion
Old Jul 13, 2006 | 05:16 AM
Mpwr's Avatar
Default Battery corrosion
whats a good technique to remove all the residue/corrosion thas on the battery n its terminals?? i've heard of usin bakin soda or coca cola?? any tips n suggestions would really be appreciated. thanks
Old Jul 13, 2006 | 05:24 AM
Jm's Avatar
Jm
Default RE: Battery corrosion
Mix baking soda and water and scrub it will a tooth brush.
Old Jul 13, 2006 | 09:22 AM
Installing anti corrosive washers on the terminals beneath the clamps will help retard the corrosion once cleaned up. Here's a picture if you don't know what I'm talking about.
http://www.matson.com.au/washers.html
Old Jul 13, 2006 | 09:35 AM
Try a little cleaning and it will work just fine..
Wire brush...battery terminal cleaner, battery brush combo kit..all found in your AutoParts store in the battery section.
Then do as RTex says , use corrision protection to keep it from getting corroded again or fix your alternator that is more than likely overchargeing your battery which is more than likely making the acid come out of the battery and corroding the top...phewww...that's alot of words.
Old Jul 13, 2006 | 08:50 PM
Uh, why is this in the detailing area?
Old Jul 14, 2006 | 12:37 AM
mbo1985's Avatar
I like to put axle grease on the terminals after cleaning them with baking soda water mix. Never had corrosion problems.
Old Jul 14, 2006 | 11:03 PM
YeuEmMaiMai's Avatar
my honda dealer did my 90K service and cleaned the terminals and sprayed them with some purple stuff that almost loosk like nail polish. 6 months and 10K miles later not a sign of any corrision.
Old Nov 16, 2006 | 02:44 AM
HondaEnthusiast
TRY THIS>>> boil some water and pour it right over the terminals and watch the corrosion disappear in seconds...Nice trick huh??? Let me know how it comes out..thanks
Old Nov 17, 2006 | 12:22 AM
19Accord97
ORIGINAL: HondaEnthusiast
Ummm.....wouldnt that be a bad idea? Ecspecially if the water made a circuit between the positive and negative terminal. Be careful if you do that, I dont think battery acid in your face would be to pleasant.
Old Nov 17, 2006 | 12:29 AM
thats old school
ORIGINAL: mbo1985
