Accord 94 windows
Old Jul 19, 2006 | 11:45 PM
zuptidi
Default Accord 94 windows
Hello there
Well i'm a Total Newbie here and was surfing through the forums for Window Help.
Here's my problem.
My passenger window seems to have trouble going back up/ closing.
Whenever i oil the tracks it works perfectly but overtime goes back to being slow when going back up.
I already read in the DIY section about windows troubleshooting.(FYI)
Now i was thinking would cleaning the tracks Help a lot?
DO i have to replace them?
Another thing is that the window goes up Slanted but right before completely closing, goes back to it's spot.
Is this Normal?
Waiting on your replies
Thank you
Old Jul 21, 2006 | 04:40 AM
Default RE: Accord 94 windows
you can try cleaning the run channel first and lube it.. see if that helps
the reason the window is slanted it could be because it is sticking on one side or it could be you got a worn out regulator ,, if cleaning does not help, you might have to replace the run channel and or the regulator
If you remove the door panel and look at the regulator you will be able to tell if it is a bad regulator of window just getting stuck on dirty channel
Old Aug 16, 2006 | 03:47 PM
fperezal's Avatar
dry chanels and worn plastic wheels is your problems. Lubricate with silicone based lub, replace regulator.
secureone
Mar 19, 2008 11:02 AM
simplytitan
Nov 18, 2007 02:08 PM
kaiotes
Dec 14, 2006 08:23 PM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
