Engine Detailing/Cleaning
Old Jul 22, 2006 | 02:16 AM
fireballer44's Avatar
Default Engine Detailing/Cleaning
My engine is quite dirty, I want to give it a good cleaning. Have any of you guys used one of the air-powered detailing guns that I see at the stores. I have little crevices everywhere full of dirt, and that would definitely save some time if the pressure is enough.
Any other suggestions? I am trying to find a way to give it a good cleaning without spending two weeks on it....I have used the foaming cleaners on other cars, this one has much more electronics under the hood and the foam doesn't really do a good cleaning even when brushed. I have used several dressings, pretty much have in mind what I want to do in that aspect, although any products someone suggests I will definitely look at. (I love to try new products as long as it is safe for my car!)
Old Jul 22, 2006 | 09:45 AM
Default RE: Engine Detailing/Cleaning
I'm not familar with air cleaning guns, sorry. You need a stronger degreaser than the foamy types, something along the lines of Simple Green or Castrol Purple Power.
I use a commercial degreaser, let it sit, then agitate very dirty areas with a brush. This may have to be done twice depending on how bad it is. Also have a supply of rags that will be pitched once done. The next step is to use a pressure washer and hit the areas well taking care not to soak down the alternator, distributor cap (if it has one), fuse boxes, etc. A little common sense is all that's required here. Do rinse down all painted areas where the cleaner might have splattered such as fenders, windshield, etc. Once clean I use Stoner's More Shine Less Time on the entire area EXCEPT for belts. Don't forget to clean the bottom side of the hood.
Once you've taken the trouble to clean it thoroughly it's a lot easier to keep it that way.
Old Jul 24, 2006 | 04:44 PM
Thanks, I will do that. I have never used the More Shine Less Time, but I love the Invisible Glass. I will probably get one of the air guns to try, they are only like $12. I will put some simple green in it. I figure it is like a small scale pressure washer, would be good for the little areas. I don't have a pressure washer.....will have to look into that.
I know it will be nice when it is clean, I cleaned my old car's engine up nice (it was cleaner than this to start) and when I sold it the guy kept commenting on how clean the engine was, made a big selling point.
I think I am going to take off that exhaust cover and paint it with some high-temp paint....like an aluminum color. It is quite discolored and looks bad.
Old Jul 24, 2006 | 09:57 PM
Before I got a pressure washer I went to the local car wash and used the wand with the engine running. If it stalled, which it never did, I knew I sprayed something that needed to be dried out before it would start. There's not as much to worry about now as opposed to carbs, distributors, plug wires, points, condensor, etc., in the old days. Just use common sense and don't high pressure everything in sight.
Almost forgot......More Shine Less Time displaces water so it can be applied to wet surfaces. Works like magic on wheel wells too.
Old Jul 25, 2006 | 01:09 AM
I picked up one of those cleaning guns while I was at Home Depot today.....$11.90. Works pretty well, I ran it at 90PSI air pressure and put the siphon in a diluted bottle of simple green. I am going to get some more tomorrow and not dilute it much and clean everything up. Will probably take it then to the car wash and pressure it off. I need to get some sort of weird shaped brush, my car has a lot of small places I need to get to.
Will the more shine less time work on the valve cover? I don't know which car you have, mine is a black metal with a texture to it. I would like to make that look nice too, it just needs a little shine.
Thanks for your suggestions....
Old Jul 25, 2006 | 11:44 AM
Yes it will.
Old Jul 25, 2006 | 03:08 PM
Working on it right now, had to take a break. I am using the cleaning gun I bought and a brush to apply the simple green. Then I rinse with water in the gun. The gun adds air (obviously, it is air compressor powered), so it makes a nice foam. I am using it solely to clean the parts I can't get to with a brush, does pretty decent, at least gets all the dust and junk off. I have some pretty thick grease/oil, it think a lot of it is from the valve cover seal that was replaced a couple months before I got the car. Old owner was original owner and took very good care of car, but engine didn't get much cleaning. And then, all the dust from my body work just made it work....
I am going to go pick up some of the stoner stuff in a bit when I finish, I will post a pic later.....I wish I had a before pic, didn't think of that before [&:]
Old Jul 25, 2006 | 06:08 PM
I love that More Shine stuff!!!!!
Thanks for the advice! After a few hours of work the engine looks great!
I attached a pic...
[IMG]local://upfiles/4768/997C5C25D27344D382DA6F9236F8B7FD.jpg[/IMG]
Old Jul 25, 2006 | 07:23 PM
nixalot's Avatar
I actually took off the heat shield you're referring too a few months back while looking for a rattle that I never found. In the process of taking it off one of the bolt heads broke off that holds it to the manifold... so, I just left it off. My take on it is that if anybody that works on the car at any point is dumb enough to touch a hot manifold then they shouldn't be under the hood in the first place (including myself... )... Once I took it off though it exposed the ugly manifold underneath... so I used some flat black high temp BBQ grill paint and sprayed it with a good coat... looks great now... [8D]
Old Jul 25, 2006 | 07:53 PM
Yeah, it looks bad on the front like that. I will probably paint it at some point. My old Pontiac I had before this car was reversed, intake in front, exhaust in back. Looked better that way.
