my '90 won't start after engine wash?
Old Oct 3, 2004 | 11:02 PM
droptail
Default my '90 won't start after engine wash?
I degreased and sprayed down the entire engine bay to replace the leaking cover gasket and now it won't start. I don't see any spark at the plug when removed and grounded to the engine. I do smell fuel on the plug. What has caused this? Is it just a mater of letting it dry out, its been about 15 hours?
Old Nov 16, 2004 | 10:48 AM
Default RE: my '90 won't start after engine wash?
Assuming that your car has a distributor remove the cap and wipe the inside out with a dry cloth. Once done spray the inside of the cap with WD-40 because it displaces moisture. Wipe it out again, reinstall and try it. Let us know....
Old Nov 22, 2004 | 03:31 PM
poff1986's Avatar
most likely your coils fried if you dont have spark. get a new coil and distributor cap then try again! good luck..
Old May 11, 2005 | 12:45 PM
Evlampius's Avatar
ORIGINAL: poff1986
yea get a new coil , costs you an arm and a leg ....try it good luck and if it doesn't work , don't blame me... [sm=boosign.gif]
theres a proper way to test every electrical part!!! DO NOT BE A PARTS CHANGER ! spend your money wisely!
Old May 11, 2005 | 12:49 PM
Evlampius's Avatar
ORIGINAL: droptail
I degreased and sprayed down the entire engine bay to replace the leaking cover gasket and now it won't start. I don't see any spark at the plug when removed.....
OMG really ??? you can't see any spark when removed??? RTEXASF - we need your magic wand here!!! please cast some of your sparking spells may be it will help and it will spark when the spark plug is removed!!!
Old May 11, 2005 | 02:01 PM
jayhova804's Avatar
ORIGINAL: Evlampius
ORIGINAL: droptail
[sm=funnypostabove.gif]
Old May 11, 2005 | 07:29 PM
accordlowered04's Avatar
i had a similar problem and it was my distributor so i would try a new one and see what happens.
Old May 11, 2005 | 10:04 PM
Evlampius's Avatar
ORIGINAL: accordlowered04
omg heres another one... so he'd buy a distributor for more than 200 bucks and if it's not the distributor??? [sm=badidea.gif][sm=chairshot.gif][sm=noooo.gif]
Do not buy a distributor unless you find the old one faulty. And theres a way to test it.
Old May 12, 2005 | 02:21 AM
If you follow RTex's lead with the cleaning out the wettness from the cap and rotor you should be alright assuming it got wet when you cleaned it up..
That's a common occurence when the engine area gets cleaned...
ORIGINAL: RTexasF
Old May 13, 2005 | 11:17 PM
Alekat's Avatar
Since this happened over 7 months ago- I would hope he/she has it repaired by now?
