steering wheel removal
Old Jul 27, 2006 | 12:34 PM
abelh7's Avatar
Default steering wheel removal
i have a 91 lx and was needing to remove the steering wheel can someone help me out?
Old Jul 28, 2006 | 12:22 AM
Default RE: steering wheel removal
ORIGINAL: abelh7
FIRST off make sure the wheels are straight especially if car has air bags
I cannot recal if your car has air bag or not ...........If no air bag it is very simple. pry put the center piece and remove the 19 mm nut . careful when you pull it out . there are some wires behing it
If it has air bags ,,,, FIRST thing you do ,,DISCONNECT THE BATTERY , make sure you have the radio code if it is anti-theft radio........Once battery is disconnected.. on the underside of the steering wheel, there is a little cap, remove the screw, inside it there is the air gag plug, disconnect it, also there is a connector in the cover, you need to install it on the air bag side of the connector,,,, Once done ,, you need a TORX socket , there are 2 bolts on either side of the steering wheel, remove the covers and you will see the bolts, remove the bolts, remove the air bad,, place the air bag in a safe place WITH THE CUSHION PART UP..........
remove the center nut , again make sure wheels are straight , pull up on it slowly and part way disconnect the wiring behind the steering wheel , you can remove it now,,
Install in rerverse order .........Any questions , Holler ..
Old Jul 28, 2006 | 04:01 PM
abelh7's Avatar
hey thanks, you would'nt believe what i been doing to try to figure it out. the resone for removing is that my horn does not work and i could see that someone cut the wire so i was trying to get to it to reconnect it.
now i am going to attempt to do an egr port cleaning hope i dont mess anything up i read the DIY on how to do it so i think i will be fine. now i just need to get a slide hammer well see.
loki16
Aug 12, 2013 06:54 AM
daddy
DIY Answers.
Jul 8, 2010 05:21 PM
CougarMark67XR7
Apr 5, 2009 04:13 PM
88exi
Feb 7, 2009 12:37 PM
