Replacing 88 Fuel Tank
Old Jul 29, 2006 | 04:52 PM
marsblackman
Default Replacing 88 Fuel Tank
The fuel tank to my 88 Accord just started leaking at the seam. There is a trail of gas everywhere I go. Some help on replacing the fuel tank would be appreciated. I plan on doing this at home. Thanks in advance.
Old Jul 29, 2006 | 06:08 PM
Default RE: Replacing 88 Fuel Tank
I've never done it myself but here's the teardown instructions! Drain the tank first.
[IMG]local://upfiles/3079/5E0E1153B0C346D3950A8A0A85B294C2.jpg[/IMG]
Old Jul 29, 2006 | 07:29 PM
marsblackman
Old Jul 30, 2006 | 03:17 PM
it is a very easy job to do,,,,,,,,,,a lot easier if tank is almost empty , it will weigh less ,,,,,,,,,
Make sure to disconnect all the wiring and hoses, fuel line , from the top side ,, fuel pump and sending unit wiring you do that from inside the trunk, remove the 2 access covers ( under the trunk mat) ,,
woody
Sep 15, 2010 09:20 AM
lilskul
Aug 6, 2007 11:25 AM
fingas74
Dec 13, 2006 10:56 PM
dwarez
Oct 11, 2006 09:53 PM
gary
May 24, 2006 12:10 AM
