20" in accord coupe 2004
Old Apr 24, 2005 | 05:56 AM
csofiarwaplau_85
Default 20" in accord coupe 2004
Hi, I have this SSR Professor sp1 19x8.5 with +55 offset.
I want to change it to a 20" rims, but how do I know the best width and the best offset for my car, can I get a 4-6 inches in my wheel's dish?
Old Apr 24, 2005 | 10:32 PM
Shocker's Avatar
Default RE: 20" in accord coupe 2004
Couldn't tell you the best width and th best offset for the car dude, but aslong as u get clearance turning then u should be ok..... may i ask why u wan to slam it with 20's? why not use a lowering kit or coilovers ?
Old Apr 26, 2005 | 06:04 PM
6thgen's Avatar
I'd keep that SSR personally, I'm on 19's too. Lowered about 2" 20's are a bit excessive and quite a bit more uncomfortable. When you have a 30lbs wheel on 25-30lbs tires on a suspension made to wear around 40lbs at the corner your car will tell you.
You can't get any wider without issues unless you ruin the camber. So look for the same offset.
Old Jan 15, 2006 | 07:52 PM
TedsF23accord's Avatar
did the 19"s make your car slower?
Old Jan 15, 2006 | 08:59 PM
o yea they lost probably as much as 7 hp with those 19s on there..
lightshow
Old Jan 15, 2006 | 09:00 PM
but..... they didnt loose any top speed though. the rate of acceleration was reduced
natareno92
Jan 6, 2015 01:30 PM
IceWind
Jul 12, 2007 09:48 AM
starbuck1975
Jul 3, 2007 06:34 PM
vwl1980
May 21, 2007 07:45 PM
Vpsophmore
Dec 4, 2006 02:12 AM
