TRANSMISSION 'D4' ISSUE
Old Aug 5, 2006 | 08:35 PM
MACCLES
Default TRANSMISSION 'D4' ISSUE
I have a 92 Accord LX 4 Door, auto and air with 177,000 miles. I am trying to track down the problem which causes the 'D4 signal light' to stay on at startup and when driving. In addition, the 'brake signal light' stays on and the car won't go into first gear from a stop. It will move but I believe it is starting from second gear and upshifts fine from there. Any ideas out there? This car is a bit ugly but is decent transportation. I'd hate to part it out with gas prices what they are today...
Old Aug 7, 2006 | 04:00 PM
Default RE: TRANSMISSION 'D4' ISSUE
get the codes, there is a writeup on how to get them in the diy section. the vss is a common thing to go out.
for the brakes, the level might be low or sometimes it will stay on if the e brake handle isnt tight enough
Old Sep 2, 2006 | 12:36 AM
MACCLES
[8D] I didn't get the codes but a quick foray into the TCU box revealed the root of the problem. A few resistors, a capacitor and who knows what were fried. I obtained a rebuilt unit and put in in. That solved the problem except for the brake light issue. So I am guessing the two problems may not be related. I have received other ideas but the e-brake is one that I had not heard of. I'll check that out tomorrow. Thanks for your helpful hints.
Old Oct 17, 2006 | 07:57 AM
YeuEmMaiMai's Avatar
that is a fairly common problem with those TCUs
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
klyphman
Oct 23, 2006 11:53 PM
