1996 EGR valve
Old May 3, 2005 | 12:56 AM
craiglawless
Default 1996 EGR valve
i own a 1996 honda accord ex 4 cylinder vtec. the milage is 155,000. i replaced the EGR valve and the EGR solenoid. my check engine light still comes on with the code for "EGR valve insufficient flow". the light remains on all the time and does not go away. does anyone else have the same problem or know else can be done? as i said i replaced the EGR valve and EGR solenoid, is there a piece i missed? thanks.
Old May 3, 2005 | 01:06 AM
Evlampius's Avatar
Default RE: 1996 EGR valve
good for you , you turned to the right place
2 questions - what is the code # you're getting
and who told you to replace the EGR valve and EGR solenoid?
Old May 27, 2006 | 08:40 AM
Sendal's Avatar
This happen with my isuzu trooper .. engine check light still on .. after i replaced O2 sensor .. but I got a good mechanic , he remove the cluster and unscew one bolt ... and screw it again to another scew hole and the engine check light off.. this might not work for honda . i just try to give you an idea .. better ask dealer person ...
peace !!!!
Old May 27, 2006 | 02:20 PM
ORIGINAL: craiglawless
insifficient flow,, it could mean that the egr passages are partially plugged..........Remove the EGR valve, look to see if there is a lot of carbon built up,,blow some carb cleaner in passage and if you have it,,,, compressed air ,,see if that helps ..
By the way you did clear the code ,,, right ?? and it came on again..?
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
RJLhonda
Sep 9, 2008 01:05 AM
jimbrown618
Jun 21, 2007 08:30 PM
