Hood Release Cable
Old Sep 3, 2006 | 12:24 PM
Bullethole's Avatar
Default Hood Release Cable
Tried to open the hood and the cable will not release the latch. Tried pulling on it with pliers but that did not work. How do I get the hood open without buggering up the grill? 94 Accord EX.
Old Sep 4, 2006 | 06:21 PM
YeuEmMaiMai's Avatar
Default RE: Hood Release Cable
might try removing the front splash guard and then reaching up to see if you can unbolt the latch....other than that I am not sure
Old Sep 4, 2006 | 11:21 PM
19Accord97
I would go with YeuEmMaiMai. When I was at Best Buy the guy recommended I get a sensor for when my hood is opend that the alarm goes off. He said its easy to open the Hondas hood because the cable is right above the fender. Good luck!
Old Sep 5, 2006 | 03:08 AM
what i have used is a screwdriver and was able to reach the hood latch and pry back on hook
another way that i have done it , is to raise the car up on the lift and use a long screwdriver form underneath
none of the cars were 94 accords ,, 2 were 86-89 accords the other was a 87 civic ..
Old Sep 14, 2006 | 06:44 PM
Bullethole's Avatar
Got it! Three bolts hold the latch assembly. Two are accesable but the other is behind a plastic panel at the back of the grill. You can see the bolt but cannot get a socket on it. Drilled a hole in the plastic that was in the way and the whole shebang came up with the hood. Cable is broken at the latch. Waiting on cable so I can get it fixed. Meanwhile I have the hood strapped down.
Thanks for the help!
RedLineZ_05
Oct 18, 2012 09:24 PM
minndogs
Mar 4, 2009 11:31 AM
katicbec
Jul 27, 2007 04:04 PM
Green_Accord
Apr 25, 2007 10:39 PM
Bullethole
Sep 3, 2006 12:23 PM
