4 ten's
Old May 9, 2005 | 03:45 AM
white98's Avatar
Default 4 ten's
has any one seen, or have any pictures of four tens in a 98-02 accord? i just want ideason how to build my box thanks
Old May 9, 2005 | 04:26 AM
Default RE: 4 ten's
I would e-mail one of the larger speaker companys from their sites and ask that question...
I'm more than sure that they would be happy to provide you with a few pictures of just that scean your looking to see...
Old May 9, 2005 | 05:21 PM
jayhova804's Avatar
Default RE: 4 ten's
if u want show quailty id go with a custom fiber glass box where are you from?? around here there are a buch of shops that do good work, and where would u mount the amps and how many are you running?
Old May 9, 2005 | 07:27 PM
white98's Avatar
Default RE: 4 ten's
ok the low down
i am going to be running
4 alpine type E 10's
2 mrd-m605 amps
1 mrd-m345(mids and highs, all alpine type-r)
3 1frad caps
i am doing the box and install myself( i am a installer)
i want to do a mdf box for now till i am willing to lose my spare
but i did just get a new job and depending on my first few checks i might go with
4 alpine type-R 10's
2 16-MCD1000 / or 4 mrd-m605's
this depends on my cost that i get each at and room. the memphis amps are very small for there power output and i just dont reall want to run 5 amps but i will if i cant find the guy that was gonna give me his discount at his shop. so i still just need an idea of the box size and shape so thats why i asked if any of you have seen it.
Old May 9, 2005 | 10:49 PM
Shocker's Avatar
Default RE: 4 ten's
Id run a ten in each corner of the runk on an angle and then ur amps in the middle on like different angles or staright etc...countersink the amps ts much cleaner my amps are....
Old May 10, 2005 | 09:19 AM
white98's Avatar
Default RE: 4 ten's
do you have a picture?
Old May 10, 2005 | 09:26 AM
white98's Avatar
Default RE: 4 ten's
as of now my idea is to v shape them kinda. and flote the amps on the back of the box with a plexi glass window, so when you drope the seat you see them or mount my four ch in bewteen them and the other two on the back. i have a few other ideas but not sure. then i still need to mount my caps. but the goal is to have acces to the spar
Old May 11, 2005 | 12:49 PM
Shocker's Avatar
Default RE: 4 ten's
I will find you a picture
Old May 16, 2005 | 08:40 PM
Burn69's Avatar
Default RE: 4 ten's
Post a pic when your done, I would like to see it.
19962door
Jun 22, 2010 10:42 AM
trystendaycey
Jun 20, 2010 03:55 PM
