How much oil?
Old May 10, 2005 | 11:12 PM
AccordJZ82
Default How much oil?
I have a 98 Accord and I was just wondering how much oil is good? I checked the dip stick but seems like you cant really tell. So just wondering how many quarts are good. I put in 4. Does anyone know for sure?
Old May 11, 2005 | 12:58 AM
jayhova804's Avatar
Default RE: How much oil?
just dont over fill it ive heard that too much oil can be worse than not enough i thought most cars hold 4 quarts of oil? maybe its 5 in not sure im not a real tuner i let jiffy lube change mine lol.
you can always check your owners manual
Old May 11, 2005 | 01:45 AM
Evlampius's Avatar
ORIGINAL: AccordJZ82
park your car at the flat surface - turn off the engine - wait 2 minutes. pull the dipstick out, wipe it with paper towel, put it in till the end and pull it out . it should read between maximum and minimum points,
if you can't read it theres a problem with your ... [:@]
j/k
Old May 11, 2005 | 11:17 AM
6thgen's Avatar
about 4.5 quarts.
Old May 11, 2005 | 12:26 PM
Evlampius's Avatar
ORIGINAL: 6thgen
about 4.5 quarts.
not quite.... depends on the capacity of oil filters and leaks and oil consumption...
so how much oil?? Exactly that much to bring the oil level between MIN and MAX points on the Engine Oil dipstick [sm=goodidea.gif]
Old May 18, 2005 | 04:46 PM
nrangerfan's Avatar
I have to agree with sixth gen. I've got a 98 4cyl and just changed last week. 4.5 quarts for me with a healthy engine and no leaks. what do you guys think about the Lucas adders always being pushed at the local autoparts stores with the crank shaft displays?
Old May 18, 2005 | 04:47 PM
6thgen's Avatar
ORIGINAL: Evlampius
ORIGINAL: 6thgen
about 4.5 quarts.
That's 4.5 on my car, never fails.
Old May 19, 2005 | 12:14 PM
nrangerfan's Avatar
So I just checked my oil and it is a bit on the high side of the max mark, am I ok? Or should I get messy and drain a bit out? It seems to be about 1/2 qt over-full (referencing 6-gen's comment, I put 5 qts when it really only needed 4.5)
98 4 cyl -
Old May 19, 2005 | 12:38 PM
jayhova804's Avatar
id drain a bit out but thats just me im not scared to get messy
Old May 20, 2005 | 01:53 AM
Shocker's Avatar
u can never have enough.... i'd leave it as it is...
