In dash clock
Old Oct 3, 2006 | 10:08 PM
Gooch
Default In dash clock
Hello all,
I've noticed from the posts here that changing the clock bulb is easy, but how about the clock itself?
Thanks.
Old Oct 3, 2006 | 11:30 PM
Default RE: In dash clock
instead of buying a bulb buy the whole clock,,
you got to pry it off to replace the bulb ,,
well depends on year and model of course .. some clocks you might have to pry the frt bazel off and remove screws
so like i always say
INPUT THE YEAR AND MODEL IF YOU WANT THE PROPER INFORMATION
By the wy Welcome to HAF..
Old Oct 3, 2006 | 11:57 PM
Gooch
Oops!
2001 Accord LX 4-door.
The clock itself isn't working and I was thinking of buying the unit and changing it myself, if it isn't too hard.
Old Oct 4, 2006 | 06:15 PM
have you checked the fuse ??
chk fuse 13 7.5 amps rt pass fuse box under dash
fuse # 9 7.5 amps driver side under dash fuse box
Old Feb 13, 2008 | 02:49 PM
jgomez630
Default RE: In dash clock Bulb 1999 accord
I changed out the clock bulb and must of caused a short because I forgot to disconnect the battery. Now all my power windows, moon roof don't work. Also, I can't shift out of park. The brake lights work. I visually checked the corresponding fuses and they look ok. Do you think it might be a relay?
Old Feb 15, 2008 | 09:37 AM
jgomez630
Default RE: In dash clock display Bulb 1999 accord
If for some reason you cause a spark when inserting the bulb, there's a good a chance
you may blow fuse #9 (instrument/brake) located on driver's side fuse panel. This causes the sun roof and power windows to not work.
Also , I couldn't shift out of park. Doesn't seem too logical , but it happens. So after following "Deserthonda" advice, I noticed fuse #9 was blown, so I replaced it. Now everything is back to normal.
ctstar2009
Sep 14, 2009 04:05 AM
lateforwork2
Nov 13, 2008 01:04 AM
bbradley
Apr 5, 2008 11:05 PM
old88dog
Jun 13, 2007 10:58 PM
DiMAn0684
Dec 27, 2006 08:20 PM
