Need procedure on fender removal - 98-02 Accord
Old Oct 13, 2006 | 01:58 PM
MiniR34
Default Need procedure on fender removal - 98-02 Accord
Just a rough set of directions telling me where to look for bolts or screws is enough. Any special tools required?
Thanks!
Old Oct 13, 2006 | 02:22 PM
Default RE: Need procedure on fender removal - 98-02 Accord
Most of the bolts are located under the hood along the ridge running from your windsheild to your headlight, then on the inside of the fenderwell will be about 8 or so self taping screws or just screws in general that hold the plastic skirt to the fender, then open the door of the car and look right in the crack where the door meets the fender and there is usually one or two bolts in there that are attached to the fender, that should about do it.... I may be missing a few but I'm not 100% sure, that should be most of them unless you have one hiding behind the headlight
Stingray
Apr 13, 2023 06:25 PM
Anse
Jun 6, 2009 05:09 PM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
Mr_Accord
Apr 8, 2007 12:14 PM
moto_man
Mar 26, 2007 07:21 PM
