'92 accord at-rear motor mount
Old Oct 24, 2006 | 12:28 AM
trvlnut
Default '92 accord at-rear motor mount
I have done a search on how to do this and I'm not having any luck so I decided to post here.
My car vibrates when idling. I had one of the front motor mounts replaced and that helped, but it's still vibrating. I'm thinking that the rear motor mount needs to be replaced.
My experience working on cars is not much. Biggest thing I've done is replace the alternator. So, does anyone know where I can find info on how to replace the rear motor mount? I want to look at the instructions (with pics if possible) to see if I dare attempt it.
TIA
Old Oct 30, 2006 | 02:08 AM
Default RE: '92 accord at-rear motor mount
before you replace it, you got to make sure that it is broken,,,,,,put a floor jack under the tranny and raise car up slightly,, look at the motor mount , if the rubber part of it separates , or you can see it broken then mount needs to be replaced ,,
assuming your car has auto tranny, there is a vacc hose that goes to mount diaphram,, at idle 700 rpm car in gear, should have vacc available at that hose ,, if you do, get a vacc pump and apply vacc at diaphram to make sure it is holding vacc and not leaking
If you need to replace the mount , i have found the best way is to remove it from under the car,
Old Oct 30, 2006 | 02:16 AM
YeuEmMaiMai's Avatar
DH is right..... you are going to have to support the engine and tring to get it from the top is a MAJOR PITB (intake and other stuff in the way)
I do not believe that you will need to remove the exhasut pipe but if you do, it will make it a little easier...
baer77
Feb 27, 2009 03:47 PM
kirakitty
Oct 30, 2008 08:55 PM
Naked TREE 2X4
Sep 1, 2007 07:38 AM
bedwards97
Mar 14, 2007 03:51 PM
Markus26
May 17, 2006 09:28 PM
