moving back to desert, coolent/ water levels?
Old May 25, 2005 | 01:26 AM
joshuaaaronalpert's Avatar
Default moving back to desert, coolent/ water levels?
Hey everybody I'ved lived near LA for a couple of years and moving back to phoenix. It get up to 110ºF in the summer. How much coolent should I put in my radiator compared to the water level? Like 8:1, half and half ratio?
Old May 25, 2005 | 02:27 AM
Default RE: moving back to desert, coolent/ water levels?
50/50 is what my dad recommends, he's lived in Phoenix for about 15 years now and that's what he recommends..
Peace Out
Old May 25, 2005 | 10:50 AM
I agree with WheelBroker that 50/50 should be on the money. Do make sure that the cooling system is in top shape including belts, hoses, and water pump.
Old May 31, 2005 | 07:02 PM
Alekat's Avatar
50/50 is recommended. Consider using the new Prestone all fluids/all colors mix. Be sure to use ONLY distilled/demineralized water - NEVER tap water.
87's incorporate two fans. One energizes when the A/C is switched on. The other when the engine temp reaches the thermostat designed temp, (190-195).
When it becomes necessary to sit stationary, in extremely hot conditions, with the A/C on, and when possible, face the vehicle into the wind, (if there is any), and watch the engine temp gauge.
Old May 31, 2005 | 07:05 PM
Alekat's Avatar
50/50 is recommended. Consider using the new Prestone all fluids/all colors mix. Be sure to use ONLY distilled/de-mineralized water - NEVER tap water.
67electro
Jul 12, 2013 05:08 PM
pdxcrx
Aug 24, 2008 08:23 PM
01HondaAccord
Jun 2, 2008 09:47 AM
19dabeast85
Jul 16, 2006 02:00 PM
mudeater18
Jul 11, 2006 11:35 PM
