Foggy Windows!
Old Jan 15, 2007 | 02:49 PM
Sparco_racingVTEC's Avatar
Default Foggy Windows!
My windows always fog up when its raining or cold out, what can i do to prevent it? Cause usually when i turn on the defroster it makes it worse
Old Jan 15, 2007 | 02:57 PM
poser_pilot6
Default RE: Foggy Windows!
Well RainX makes an anti fog stuff that you put on the inside of your windows, from what I have heard, it works pretty good. I've been meaning to get some, I have the same problem with the foggy windows. It helps to use your defroster on cool, instead of heat. Once the fog goes away, you can put it back on heat. Also, make sure you are on the fresh air setting, not recirculate.
Old Jan 15, 2007 | 10:38 PM
Keeping the windows extremely clean on the inside helps a lot. Try turning on the defroster before you actually need it in order to keep the windows from fogging up in the first place.
Old Jan 21, 2007 | 04:47 AM
19Accord97
I have the RainX glass wipes w/ anti-fog and for some reason, I had a horrible time w/ them. It made the windows streaky, and then my windows started getting cloudy. I had to clean em' off with Stoners glass cleaner. It seemed as though the RainX was applied to heavily, which doesn;t make sense considering it was the wipes.
Old Jan 22, 2007 | 05:32 PM
1stAccord_2ndHonda's Avatar
ORIGINAL: 19Accord97
I use RAINX all the time... you're supposed to buff the haze away with some water (not too much) and a chamois... it's like a waxy material so it needs to be buffed... once it's buffed.... it's awesome...
Old Jan 23, 2007 | 01:48 AM
19Accord97
Hmph! Didn't know that. I'll def. try that. Thanks.
DigitalDharmaBum
Jan 20, 2015 12:33 PM
Josh's Accord
Sep 9, 2011 07:24 AM
FoggyO
Mar 27, 2009 11:37 AM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
