Brake Pads
Old Jun 16, 2005 | 03:11 PM
mansugi
Default Brake Pads
I drive about 110 miles a day to and from work. I have been changing my brake pads (front only) every 6 month. Is this normal ????
Old Jul 24, 2006 | 03:29 AM
ACCORDRYDLX
Default RE: Brake Pads
YEA
Old Jul 24, 2006 | 03:31 AM
Do you rotate your tires alot?
Old Jul 24, 2006 | 04:25 AM
no that is not normal..
to drive so many miles per day it kind of tells me that it is mostly highway miles ....
lets say yoiu drive 110 miles a day x 25 days a month . i just split 30 days and 4 , 5 days week.. anyho it comes to 2750 miles per month x 6 =16,500 miles ,, that is way too little miles for a set of pads to need replacing ,,,,,
Now , on the other end if you do mostly stop and go driving than it is a different story,
when you replace the pads are you using Honda pads ??
Also,, as suggested by Wheel......, you should rotate the tires every 3 months ...
Old Jul 30, 2006 | 10:12 AM
dagher
Hi All,[&o]
i have the same proplem but i do chang the front & rear every 8000 KM and disk surface is this normal i have Accord 2006 i drive 17000 KM up to now.
is this normal or thir is defact. [X(]
Old Jul 30, 2006 | 03:57 PM
ORIGINAL: dagher
Hi All,[&o]
Wow ,, you need to have it checked out at the dealer , car is still totally under warranty ,,( unless you drive with your foot resting on the brake pedal )
8000 km is less than 5000 miles ( 4970.96 ) to be exact ..
Brake pads should last at least 30,000 miles ( 48,280 kim )
deserthonda
Nov 9, 2013 04:18 AM
sach4u1
Oct 10, 2010 03:12 PM
J2Performance
Jan 15, 2008 04:29 PM
jboates
May 17, 2005 10:16 PM
