please answer ASAP
Old Jan 23, 2007 | 12:10 AM
foxracing31702's Avatar
Default please answer ASAP
im tryin to put new rotors and pads and my 92 accord. on thefront end...the big nutt that hold the studs and rotor on, is it left hand threads or normal?? i got disc all the away around...and also if you got any helpful tips. let me know
Old Mar 22, 2007 | 11:51 PM
Shadow1992's Avatar
Default RE: please answer ASAP
Normal threads. I got a '92 myself. But the down side is they are torqued to 250 ft-lbs, and if yours are installed correctly then the nut rim has a section dented in to a slot on the axle to prevent the nut from turning on it's own.. What you'll need to do is pry that dented section out without damaging the threads on the axle. Now if you don't have a half inch impact gun operating at 100psi, you'll have to do what I did the first time I took them off. get a 36mm nut and cheap breaker bar from like an autozone. Go to a hardware store and get a 4ft pipe that the shaft of the breaker bar will fit in (you may have to cut the handle at the end of the breaker bar off to get to fit in, the idea is to have as much of the shaft touching the inside of the pipe as you can). Then just take the nut off. Installation is reverse of removal
Old Mar 23, 2007 | 12:47 AM
Very good answer Shadow, you have that down pat..
Rockcity
Feb 10, 2013 01:10 PM
oIACCORDIo
Feb 17, 2010 08:55 AM
christian2000accord
Jul 29, 2009 02:24 AM
YeuEmMaiMai
Aug 14, 2006 07:02 AM
fryhead
Feb 27, 2006 10:04 PM
