Keyless Entry Programming ....ZRO26T'S
Old Feb 23, 2007 | 06:08 PM
Default Keyless Entry Programming ....ZRO26T'S
Thanks to ZRO26T'S ,, who found this useful site..
http://www.honda-acura.net/forums/showthread.php?t=202634
here's zro26t's instructions Also,
2000 and 2002 Accord SE with factory-installed security system
1. Turn the ignition switch to ON (II).
2. Press the "Lock" or "Unlock" button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the "Lock" or "Unlock" button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the "Lock" or "Unlock" button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
Arsalan03
Jul 24, 2010 11:08 AM
Jeffrimerman
Aug 4, 2009 04:36 PM
samijean55
Jul 28, 2008 09:48 PM
St3v3
Jun 2, 2006 06:01 PM
93Miata
Nov 10, 2005 08:06 AM
