MOTOR MOUNTS (Driver's side and rear)
Old Feb 24, 2007 | 08:16 PM
suprarx7nut's Avatar
Default MOTOR MOUNTS (Driver's side and rear)
Ok so I've been told by more than one mechanic that all my mounts are shot. Now I replaced the front and tranny mounts no problem. Now I'm trying to do the driver's side and when i start to unbolt it, the entire engine drops!
How should i be replacing this? The others didnt cause any movement of the engine when removed. I s something else wrong? Do i need to support the engine before removing this mount?
Whats up?
Thanks in advance.
Old Feb 25, 2007 | 03:03 PM
Default RE: MOTOR MOUNTS (Driver's side and rear)
yes the engine will drop a bit,,put a floor jack under the engine ( oil pan )if you do not have one use the one in the trunk when you change a flat tire ..
Old Feb 25, 2007 | 05:55 PM
Thanks for the fast response. I tried to support it by the oil pan, but it still dropped. I tried to lift the engine by the oil pan just a tad after it had dropped and it just rose th entire car! I'm a little confused. I'll have to try again and see if i was missing something.
Old Mar 15, 2007 | 09:00 PM
What do i need to do to get to the rear mount?
I cant find anything anywhere. My service manual only describes it if you're removing the entire engine.
THANKS IN ADVANCE!!
Old Jun 17, 2007 | 10:51 PM
I'm trying to remove that rear mount now and I've got it unbolted, but can't get the bracket or mount out of the engine bay!!! I removed the air intake, of course, and have undone all necessary bolts, but cant pry it out.
ANY TIPS/TRICKS or advice? I'm dyin here. I need it done by tomorrow evening. Thanks!
Old Aug 26, 2010 | 01:58 PM
land shark's Avatar
I am having the same issue with my 1990 honda automatic 4 door. The vibrations start when the car is in reverse and seems like it is going to shake the enitre motor loose eventually.
I also need some dIY advice to be able to tackle this my self. I could not come across any more information as in a step by step and what tools you would need to tackle the rear mount. Thanks and good luck
mpanelli
Nov 9, 2014 08:39 AM
jza240sx
Apr 30, 2013 04:14 PM
bvkiran
Mar 3, 2010 10:23 AM
jose310
Feb 1, 2008 07:44 PM
19accord92
Apr 10, 2006 03:52 PM
