offset
Old Mar 23, 2007 | 03:54 PM
Honda_Dude's Avatar
Default offset
whats the offset on an 1998 Honda Accord V6 and a 2002-2004 Acura RSX Type S??
Old Mar 23, 2007 | 07:22 PM
Default RE: offset
Hello HondaDude:
Here is the official answer...
98 Honda Accord V6 5x114.3 offset High 42-55mm Lug Nut 12mm x1.50mm
02-04 Acura RSX 5x114.3 offset High 42-55mm Lug Nut 12mm x 1.50 mm
I have spoken, well I have typed
Old Mar 23, 2007 | 08:56 PM
Honda_Dude's Avatar
Default RE: offset
thanks wheelbrokerang that cleared lots of thing up
Old Mar 24, 2007 | 12:00 AM
MacLeod's Avatar
Default RE: offset
How about on a 07 Accord?
I cant stand the idea of driving around on hub caps! [:'(]
So Im going to eventually get a good looking set of 15" wheels. I dont want a larger wheel because I like riding on as much soft rubber as I can and I want it to be the same 15x6.5 as OEM cause I want to add no weight to the 4 banger.
I do however want them to stick 1"less backspacing so theyll even up with the wheel wells and not look so anemic.
Old Mar 24, 2007 | 06:44 PM
Default RE: offset
ORIGINAL: Honda_Dude
Your Welcome Honda_Dude, happy to be of service for you!
Old Mar 24, 2007 | 06:48 PM
Default RE: offset
ORIGINAL: MacLeod
Hello MacLeod..your 2007 Accord has the following:
The BP is 5 x 114.3 , yourOffset is also High +42 - 55 mm and your wheel lugs are 12 x 1.50 mm..loads of wheels you can put on your ride...
WheelBrokerAng[sm=bling.gif]
Old Mar 25, 2007 | 02:54 AM
MacLeod's Avatar
Default RE: offset
Thanks brother!!
I get the bolt patern and lug size but the offset threw me.
I thought it was just one number like 55 mm positive or negative. I dont understand the 42-55.
vintageant
Feb 1, 2007 02:14 AM
thunder_x
Nov 6, 2006 01:22 AM
STRIKER
Oct 6, 2006 07:15 AM
beauespirit
Apr 7, 2006 05:01 AM
magnod
Jan 23, 2006 03:32 PM
