subs
Old Aug 4, 2005 | 06:55 AM
jjang
Default subs
Does anyone know if 2 ten inch alpine type R hits harder or 2 ten inch rockford fosgates.
I need to know asap because i traded my fosgates in for alpines because i heard it hits a lot harder, but it seems like it doesnt.
Old Aug 4, 2005 | 05:45 PM
accorddriverc's Avatar
Default RE: subs
did you check the rms and maximum watts on each. Just the name alone will not help to determine that. Do you know the model numbers? The amp also makes a difference.
Oh I think this should be in the audio section
Old Aug 9, 2005 | 10:51 PM
davidatug3
Default RE: subs
the ten inch fosgates hit harder
Old Sep 29, 2005 | 12:33 PM
Shocker's Avatar
Default RE: subs
Hey everyone Im back long time no see
It's all gonna come down to the amps your using to push the subs, also what series of subs are they high or low end..... i've always heated Alpine but they do make some good products.
Old Nov 10, 2005 | 11:54 PM
7thGen's Avatar
Default RE: subs
My girlfriend has two 10" Type-R Alpines in her car with an Alpine amp pushing 900 watts and they pound. They would be stronger but the box they are in has a couple leaks that we are trying to fix.
Old Nov 18, 2005 | 04:32 PM
MECPcertified's Avatar
Default RE: subs
you also have to consider an actual decibal increase. they may actually be louder but not enough to notice. i cant remember the exact figure but to double your sound output you have to quadruple your power and double surface area. the easiest way to get more bass is to add subs or get bigger subs. they move more air!
Old Nov 18, 2005 | 08:17 PM
zelseman's Avatar
Default RE: subs
while someones on the subj. i just got two sony explod 10in enclosures, with 300 watts each, how big of a sony explod amp do i need?
Old Nov 18, 2005 | 08:36 PM
Default RE: subs
just a small 2ch amp would probably be fine there is a sony amp that the model no. is like 2100gtx that would be fine
Old Dec 4, 2005 | 11:20 PM
remington870_20ga's Avatar
Default RE: subs
Wrong section... moved
dave118811
Apr 3, 2006 07:52 PM
zelseman
Dec 1, 2005 09:31 PM
jjang
Aug 10, 2005 04:14 AM
jjang
Aug 4, 2005 06:50 AM
