Where do you run Amp Power Wire through firewall?
Old Aug 8, 2005 | 12:42 AM
Burn69's Avatar
Default Where do you run Amp Power Wire through firewall?
I have an 04 Accord 4dr and I was wondering where everyone has been running the amp power wire through the firewall to get inside the vehicle? I have to run some 1/0 ga wire and cant seem to find a place to run it through. I had a 4ga wire running through a hole in the frame into the car, but the whole is only big enough for a 4ga wire
Any suggestions would be appreciated
Old Aug 10, 2005 | 04:10 AM
98slaminaccord
Default RE: Where do you run Amp Power Wire through firewall?
ok if u have a auto then this is a simple fix u can drill threw your clutch plate i am not to sure if u have a standard haven't had to deal with that one yet
Old Aug 11, 2005 | 12:01 AM
theycallmerickjames's Avatar
with a wire that THICK you gotta drill a hole... do what he said, right thru the clutch plate.....
Old Nov 14, 2005 | 04:22 PM
love4car
Where is the clutch plate on the 05 honda accord 4 door
Old Nov 14, 2005 | 07:33 PM
MECPcertified's Avatar
the clutch plate is just to the left of the brake pedal. just look for a cut out in the foam against the fire wall and you should be able to drill as big as you need.
Old Nov 14, 2005 | 09:34 PM
7thGen's Avatar
Isn't it nice of Honda to prewire the cars for every factory accessory they make so they don't need extra holes in the fire wall.
Custnam
May 13, 2015 12:23 AM
Mark TFID
Mar 7, 2013 07:42 AM
sharma70
Feb 25, 2013 10:23 PM
central34
Mar 30, 2011 07:21 PM
bpo145
Sep 17, 2006 02:25 PM
