Bondo-ing Door
Old 12-21-2010 | 01:18 PM
something4nothing's Avatar
Default Bondo-ing Door
So I am thinking of doing some body work on my rear passenger door.
The person I bought it from had a minor incident and now there is a gash about 3/4 inch high by about a foot long in the dead center of the door going the length of the door.
I have done some body work in the past but have always had the end result of after painting, the work still shows slightly thorugh the paint.
I am guessing this is because I didn't use fine enough sand paper to smooth out the bondo after applying.
I usually use something like 220 to rough sand it and then like a 300+ grit to sand it before painting.
Should I use something a bit higher for the fine sanding and prep before paint?
I am trying to avoid that sheen the bondo areas tend to get after paint is applied.
Any help is appreciated
HondaJunkie87
09-28-2011 01:16 PM
HondaAccordEX94
DIY Answers.
04-01-2010 05:45 PM
HondaAccordEX94
03-16-2010 07:56 AM
Cinci90
20
12-29-2008 07:55 PM
reinventingaxlrose
08-26-2008 11:50 AM
