Fog Light install
Old 06-08-2007 | 12:26 PM
ducatiff's Avatar
Default Fog Light install
Has anyone installed fog lights on a 03-06 coupe? I don't like the way that the front end looks and see tons of aftermarket OEM style lights on Ebay. I was just wondering if anyone had put any of these on and how was the installation.
Old 06-18-2007 | 12:23 PM
ducatiff's Avatar
Default RE: Fog Light install
Nobody has added any fogs???
Old 06-18-2007 | 03:37 PM
jipmpizzle's Avatar
I tried to install the OEM ebay ones on my 05...they didnt work but it was something I did because I took it to the dealer because I thought they could easily make them work but they said I had a constant current running through my car (WHEN IT WAS OFF WITH THE KEY OUT)..they wanted to fix it but it would cost regular labor ($360) for them to go over what I did and find the problem...so I said f**k that and I yanked everything out and just left the fogs in...so I pretty much have the fogs in just for appearance
Old 06-22-2007 | 03:51 PM
rob3201's Avatar
If your handy, the install is easy and the directions are clear and precise. If your not handy, let the pros do it. Buy OEM, they last longer and fit great.
Old 08-22-2007 | 05:42 PM
ochondakidd
I have bought oem fog lights off of ebay for my 04 accord and they look great. I used only the wiring that hooked up to the backside of the fog lights and then i cut the right after that and ran my own and used my own switch in the car. The wiring harness that came with mine were not long enough to run. The only down fall with running your own wiring is that then you dont have the relay switches and and when you turn the car off and leave the foggies on there is no beeping or buzzing like if you left your headlights on or if you left your key in the ignition and opened the door.Oh and also they did not come withall the screws and washers i needed so i had to use my own for the missing ones.Other than they they look and work awsome and i am glad i got them.
AccordianPlayer
10-16-2012 01:01 PM
05blkaccord
09-30-2012 10:21 AM
kuthedude
06-24-2010 11:14 AM
AFTricker
12-31-2009 06:25 PM
Josh2002SiR
06-22-2009 04:04 PM
