Maint Req'd
Old 09-14-2008 | 02:49 PM
BlackONBlackV6
Default Maint Req'd
I have an 05 coupe and it is at 36,500 miles. The damn Maint Req'd light came on and won't go off. How do I turn it off without going into the honda stealership to get it maintenanced?
Is there any way around this?
Thanks
Old 09-14-2008 | 10:52 PM
03AccordEXBoston's Avatar
Default RE: Maint Req'd
yes i believe if i remember correctly you keep the key in the on position without starting the car and hold down your trip/odometer button on the cluster for like 5 seconds or so. It is in the manual if you have one if that doesn't work let me know and I will double check my manual.
Old 09-15-2008 | 10:43 AM
falkore24's Avatar
^^^^ Close. Hold the reset button before you turn the key to on. Don't start the engine, just turn it on while holding the button .... 5-10 seconds and the light will go out. This is in the owner's manual.
Old 09-15-2008 | 10:50 AM
08coupex's Avatar
Not sure if this is true, I was told you can turn off the maint, light perminently so it never comes on.
Accord Owner
03-11-2010 09:47 PM
Kube
05-31-2008 11:02 PM
zoominhuman
11-19-2007 11:28 AM
Jeffmo
08-19-2007 09:17 PM
mrmookie123
04-07-2007 04:19 PM
