Wiring for Headlight LED's???
Old 04-28-2008 | 01:38 PM
98CoupeW/Carbon
Default Wiring for Headlight LED's???
I have the projector beam headlights with the LED BMW style rings and I need to know how to wire them up.
The wires for the led's(red & Black)are seperate from the normal headlights and turn signals.
can anyone give me some advice for the best way to wire these, currently I have them spliced directly into the headlight wires but I'd like to do it proper and I would like to wire them to a switch next to the cruise control button on the dash so I can turn them on and off at will.
Thanks in advance for the suggestions
Old 04-28-2008 | 01:43 PM
finch13's Avatar
Default RE: Wiring for Headlight LED's???
I had mine spliced into my parking lights and they worked great. If you want them switched, create a new positive lead from the fuse panel, run a 1 amp inline fuse, then run it to the positive terminal on your switch, then connect the negative to any grounding point on the chassis. Same goes for the negative on the LED lead.
Old 05-11-2008 | 04:12 PM
98CoupeW/Carbon
df
tobybul
12-20-2013 03:26 PM
brandondgordon
05-04-2013 09:27 PM
Albert W
12-10-2012 05:34 PM
Cody_754
05-28-2012 03:45 PM
timgeorgi
03-02-2008 07:12 PM
