09 accord, backlight, turn signals doesn't work
99 accord, backlight, turn signals doesn't work
so the clock backlight went out, i ended up replaced the whole hazard switch and clock module. the replacement i got supposed to work for all years from 98-02.
after the replacement, all backlights and the turn signal no longer work.
i have checked the fuses, they are good, and the weird thing is that: if i press the hazard switch, the backlights came on, but not the hazard signaling ..
i put back the old hazard switch, the hazard signaling still work, but backlight still isn't working, wonder what i have busted from this process.. sigh..
(it is a 1999 accord)
any pointer would be appreciated..
How many plugs are there? You may have them backwards. If not that, do the dash lights without the hazard/switch clock plugged in? If not that either, you may have picked up a switch you thought was new. May have to get a brand new one.
Pajamarama
06-08-2012 09:57 AM
hondacow
04-20-2008 03:02 PM
