09 Accord Want a system but want to keep factory radio
#21
so i have these kicker substation 80's they are 8inchers, one is missing a speaker and the other one is the original not sure if its shot or not need to hook it up, was thinking about just replacing them with a kicker comp 8" speaker, should i get a 4 or 8 ohm speaker?
the one i looking at specs:
- 8-inch Comp Subwoofer with 4-ohm impedance
- Performs in free-air applications as well as in vented or sealed boxes
- 200 Watts RMS (100 Watts peak) power handling
- 30-500 Hz frequency response
#23
#25
there are many 8 ohm car audio subs out there. back in the 90's there were more 8 ohm than 4 ohm subs. it facilitated wiring two in parallel for a 4 ohm mono load you could then power from a 2 channel Class A/B amp. Higher impedance results in a better damping factor for the amp. a higher impedance is easier to power, just more expensive to power.
Kicker, like many others, usually offered 8 ohm or 4 ohm for their SVC subs.
#28
Those wattage ratings are suspect, RMS power is always less than Peak power. Either those numbers are reversed or they had a typo. typo's happen on websites, but owner's manuals are usually correct.
i like to have 1.5x the RMS power rating of the speaker available, that way I can set gains based on RMS speaker rating and not worry about pushing the amp into clipping or distortion.
#29
Man i am so torn as to what to do here, if i end up getting a head unit we are talking about ripping the car apart and a crap load of work, on the flip side i can get a LOC and an amp and hook up my one existing box and be done with it. Buy a half descent amp so that if i ever get a better box and or head unit i can utilize the amp i have.
Questions:
what does SVC vs DVC mean. For my application of just wanting a bass sound from the speaker which would be best
also what does it mean when you run something mono, does that just mean one speaker?
Questions:
#30
SVC is Single Voice Coil.
DVC is Dual voice Coil
DVC offers higher power handling (sometimes) and more wiring options. DVC is also great for getting a lower impedance load. jL and other constant power amps can make rated power at a range if impedances.
Unless you have a large budget, build in pieces. Start with a good amp, like the JL slash series, and a good sub. Later, you can upgrade the HU, speakers, etc.
