1997 Accord Keyless Entry Installation Help
#21
1. So, did you get the door unlock and lock to work?
2. For the 12 volt constant power, the white wire along the ignition switch harness is a source of 12 volt constant power. The ignition switch harness connector is the 7-P brown connector (connector C902) at the interior fuse box and runs up to the ignition switch.
#22
to make sure it wasnt the button i switched the wires around so the lock and unlock are swtiched and the unlock still worked but the lock didnt. Maybe the black/white wire isnt the lock? the connection is secure for sure. Im not sure why it wont lock. i might try to disconnect it and remake the connection with another quick connector.
#25
only thing i didnt install was the engine cutoff and trunk release because well it didnt make much sense to me. on the schematic but the main things are installed
and i dont think i can install trunk relay seeing as i dont have a electronic controlled trunk switch. its just like a manual latch i pull
Sjh981
05-05-2015 11:09 PM
Ojie
02-24-2014 12:28 PM
benriggle
10-25-2008 01:48 PM
