2004 Aftermarket Power but NO SOUND!?
Old 07-16-2011 | 09:32 PM
ApleSmaple1981's Avatar
Default 2004 Aftermarket Power but NO SOUND!?
Greetings,
I have read a bit on the failure of the factory radio. I do suffer from intermittent bouts of working and not working. The backlight has not worked in awhile, and now the radio shuts off when it wants to, with a CD player that is useless.
I ordered an aftermarket CD/FM player from Crutchfield, and being the novice I am have run into a bit of a mess.
I spent hours trying to hook this thing up.
Finally I get to a point where I think I am home-free and as I reconnect the battery I notice that the power to the new unit goes on, but there is NO SOUND!!!
Is this related to:
1. The fact that the original radio/components aren't working properly
2. I hooked it up incorrectly
Thoughts?
Thanks in advance!
Old 07-17-2011 | 07:18 AM
PS. This morning I tried to fix it and noticed that when I reconnect the battery there is a "ding" sound that is constantly going.
The automatic locks don't seem to be working well either.
When I unplug the aftermarket radio (which still has NO SOUND) everything reverts back to normal.
help please!!! Thanks in advance.
Old 07-19-2011 | 01:39 PM
keep_hope_alive's Avatar
sounds like you made incorrect connections. did you install the aftermarket radio in the pocket below or did you get the large kit that replaces the manual A/C controls?
did you bypass factory radio wiring with the 70-1720 Metra harness or intercept wiring with that and the 71-1720 harness?
describe each wire connection to the aftermarket head unit.
paladyr
11-08-2015 06:28 PM
cat2115
04-26-2014 08:49 AM
damarky
06-03-2012 12:27 AM
jwcorder
05-12-2008 11:33 AM
zubes
10-20-2006 06:36 AM
