6.5" Speaker Fit Front with OEM Grill?
I am restoring a 1991 Honda Accord SE.
I like to know if a 6.5" round speaker can be installed to replace the 4" and afterwards can the OEM Honda grid be placed back on to cover the new 6.5 speakers.
Here is the speakers I am think of getting are Polk Audio SR6500s:
Speaker Size6 3/4 Design2-wayTweeter Design22mm Ring RadiatorTweeter CompositionFabricWoofer CompositionAerated polypropyleneWoofer SurroundButyl rubberParts Warranty3 YearsLabor Warranty3 YearsSpecificationsSensitivity90 dBFrequency Response40 - 30k HzRMS Power Range (Watts)50-125Peak Power Handling (Watts)250Impedance (Ohms)4Top-mount Depth (Inches)2 9/16Bottom-mount Depth (Inches)2 3/4Cutout Diameter or Length (inches)5 5/8
"The installer at the installation shop said he would just cut the pod opening bigger and place them back in."
If you don't think it is possible; then is the 5.25" better?
Thanks for your help.
RE: 6.5" Speaker Fit Front with OEM Grill?
Are you planning on amping them? If not I would look for speakers with an even lower power rating and higher sensitivity. Although these would work ok with low power, they will sound much better amped. Now I don't know about the fit, but 5.25" may fit better and you may prefer the sound of them also. 5.25"s give you more mids and mid bass, while 6.5's will putout more bass and less mid bass and mids. The bass output on either will be minimal if you don't amp them. Without enough power those speakers will sound muffled and not very sharp.
ORIGINAL: t00fatt
Yes it will have a sub which is already purchase a 10" sub. I have already purchased the Alpine pdx-5; a digital amp that I take with Alpine technical support that state that is under rate in RMS. The specs are 75W RMS @ x 4 - 4 OHMS; 300W RMS @ x 1 - 2 OHMS. I think you can assume that true RMS output is at least 15% more. It so small too! I going try to have the install shop do it in the passenger seat!
Can anyone here know for sure if a 6.5" will fit in properly so that the OEM grids covers will fit back in? If not; how about the 5.25" rounds?
Thanks!
I just got an alpine PDX-4.100M amp for my boat. While its a marine its still the same yet its 100w x 4 at both 2 and 4 ohms. Its so small, and supposedly doesn't produce any heat. I haven't installed it yet as I'm still recovering from a recent shoulder surgery. I really can't wait to hear that amp, I also ordered a pair of JL 7" marine componet 100w speakers and a JL 10" W5 marine sub for the boat also. When you get it set up let me know how the amp sounds with the highs. I never heard a full range digital amp, but I have high hopes. As for your question it's going to take a while to get that answer. Not many 4th gens with high budget systems around these days.
ORIGINAL: t00fatt
I know it will sound great! Alot of very positive on reviews by owners of the Alpine pdxs. The pdx-5 just got back into stock this week!
ORIGINAL: t00fatt
That's a lot of money for a 17 year old car. Any particular reason you choose a 4th gen accord?
Just wanted to have an atypical car that is a part of my younger years! It has no airbags too! I thinking about those Porsche type seats too! But one step at a time. I want to get the car finish and maybe next year I can add on to it! It will be then stored in the coming winter and drive in the late spring to fall months next year.
I not sure about reporting the upgrades to the insurance company! It will sky rocket the policy but I afraid that that what I will have to do when it gets upped for the insurance coverage.
I think the total cost will be close to the $35K range!
What block are you using? I've seen a lot of people concerned with the compression from a single turbo. How are you going to keep the turbos from overheating. A turbine spinning at 200,000 RPM sure produces some heat, then add that to extra heat from the nitro. I'd be worried about that set up.
ORIGINAL: t00fatt
