8th Gen Stereo Replacement (W/ Nav)
Old 05-19-2024 | 03:23 AM
Ash's Avatar
Ash
Your connections look good.
it does not matter where you connect your red wire.
in that case, you need to look at software settings, or the pink wire is not the reverse trigger wire.
Later is unlikely, because headunit manufacturer has confirmed that pink is the reverse trigger wire.
that leaves us with software settings or defective headunit.
I have never used android headunits, therefore I can’t give you advice on software settings.
you can try updating the software.
and seek help from the manufacturer.
  #62
Old 05-20-2024 | 02:04 AM
donccord's Avatar
Originally Posted by xiongoliver
I still have the can bus on it and it does work. I am able to use my steering wheel controls to skip songs and volume up and down. It just doesn't work when I use my radio. So you think it is messing up my reverse light? If so then I will take it out and see
Thanks!
How did you get the canbus to work? when its connected, it does work but the A/C will turn on and off quite frequently by itself. Can I see how you connected the wire to the head unit?
  #63
Old 05-20-2024 | 06:44 PM
xiongoliver's Avatar
The power harness from the head unit has alot of plugs. I was able to put the can bus device on a white male connector. Then on the other end is a 8 pin connector that plugs into the head unit. My volume and channel change works only on the head unit. It doesn't work on the factory radio which I use instead of the new head unit.
  #64
Old 05-25-2024 | 12:19 AM
donccord's Avatar
how does one wrap the harness behind/to the right of the vents so I could fit in the radio
  #65
Old 08-05-2024 | 06:19 AM
Ash's Avatar
Ash
I have created this video to share my installation experience,
  #66
Old 09-21-2024 | 05:00 PM
Fame1418's Avatar
Originally Posted by Ash
here are some photos of the frame that I made to hold the headunit in place.
Ihave 2011 Honda Crosstour Exl navigation too I'm going to finally install this setup
Can I ask were can I get the mount for the Unit to stay in place
DeusExM1
04-26-2024 09:49 AM
Walter White
07-30-2012 04:46 PM
Persian_prince
05-13-2010 11:38 PM
Smudgie
09-07-2009 05:19 PM
ak47
02-20-2006 11:41 PM
Quick Reply: 8th Gen Stereo Replacement (W/ Nav)
