99 Accord remote wire
Where is the remote amp wire for this car? I have a amp with a high level input.
I found a PDF, if you google "Accord 1999 radio replacement" it should be on the first link.
On the PDF, PIN "I" is the "HONDA AMP GROUND WIRE" should I use that?
My headunit only have 16 pins with the harness.
The headunit have 2 adapters, one already have a harness the other doesn't, is the 17th pin on the other side of the adapter? I mean next to it.
https://docs.google.com/viewer?a=v&q...SYcE7tZA&pli=1
Nvm I found
http://crutchfield.custhelp.com/app/...honda%20accord
so just add a pin to the 17th slot? I'm pretty sure I only got 16 pin slots on the adapter that is already connected with the harness, I'll check tmr
Nvm I found
sorry, my bad. i was referencing a 2005 for some reason.
Here is the remote wire addition i did to my 2001 Accord HU. We should have the same harness - mine is 20 pin.
If your head unit has a 16 pin harness, then i'm not sure which is the turn-on wire. could be one of the three "do not use" pins. you'd have to use a DMM to verify.
Yeah, thanks for your help anyways.
Is there anyway for me to find a more accurate layout for the radio?
PAC AOEM-HON20 Add an Amplifier Adapter, Car Stereo Kits, Audio Wiring Harnesses, Installation Equipment, Electronics, Accessories & Adapters
2007accord
02-14-2007 01:57 AM
