Adding a powered subwoofer and Alpine KTP-445U Power Pack
Old 06-20-2013 | 11:01 AM
reklawj's Avatar
Default Adding a powered subwoofer and Alpine KTP-445U Power Pack
Will I still need to disable ANC if I am only adding a powered sub such as the Kicker - Hideaway 8" Subwoofer
I also wanted to add the Alpine power pack wanted to your thoughts on whether or not that would create problems as well.
Old 06-20-2013 | 10:55 PM
neophyte's Avatar
the power pack should not cause problems. if you get feedback then you will need to disable the mics. if not then you wont need too.
Old 06-22-2013 | 11:56 PM
keep_hope_alive's Avatar
because you are changing the amplification of the speakers, you will need to disable ANC.
Old 06-23-2013 | 12:55 AM
neophyte's Avatar
here is a question that this thread makes me think of. KHA: would you even be able to add the power pack in or would you have to bypass the factory amps. (i am thinking the newer ones have external amps).
Chach769
03-24-2013 02:45 PM
iluvsnapple
08-19-2011 07:51 AM
felpz420
06-27-2011 10:41 PM
dalilama
11-07-2009 09:08 PM
64tinc
06-22-2009 12:48 PM
