Amp help on 2010 Accord with Nav
Old 09-13-2010 | 05:32 PM
amjackson's Avatar
Default Amp help on 2010 Accord with Nav
Hey guys, like I said I have a 10 accord v6 with the factory nav and upgraded stereo system. I've installed aftermarket amps many times but never with a factory head unit.
I have the inline input for the rca's ran from the factory sub thinking that I can use the factory sub level controls in doing this.
Problem is, when I connect the aftermarket sub to the aftermarket amp I have a constant bass stream, or a constant rumble. Not music.
Only thing I can figure is the placement of the inline thing or maybe a ground. It was a pain finding a good place for the ground. Was hoping not to have to pull out the factory unit.
Any help would be great
Old 09-13-2010 | 10:51 PM
troycifer's Avatar
so the factory sub has a pair of output rca's? and youre running your rca's from the factory sub to the aftermarket amp?
Old 09-14-2010 | 02:27 AM
keep_hope_alive's Avatar
no, he's using the factory sub speaker wires as a high level input for the amp.
what amp make/model? sub make/model/voice coil?
Old 09-14-2010 | 10:25 PM
troycifer's Avatar
amps usually cant handle there inputs above 6 volts.
Old 09-15-2010 | 08:45 PM
amjackson's Avatar
Actually figured it out. Seems whenever the aftermarket sub would get under the factory sub, it caused the sub to do whatever it was doing. Sorta like when you put two microphones close together.
Unhooked the factory sub, and no problem. Not sure the cause of this, but it works for now. Would like to have the factory sub working as a mid so any ideas would be appreciated
Old 09-15-2010 | 08:57 PM
that's why many amps have high level inputs separate from RCA inputs so you can feed them a signal directly from head unit outputs. The JL amps also have an auto turn-on with the high level inputs so you don't need a remote turn-on when adding on to factory systems.
my amps have 9V unbalanced and 18V balanced inputs.
Old 09-15-2010 | 09:00 PM
sounds like the new sub was moving the cone on the factory sub which caused a signal on the speaker wires (magnetic induction) - so yea - feedback. i assumed you disconnected the factory sub first.
you'll need to build an enclosure around the factory sub to still use it. your best bet is to remove it and let more bass out of the trunk through the opening. your front and rear speakers should provide midrange.
jrasero
02-27-2013 06:06 PM
famouseric
10-30-2012 05:20 PM
djponrua17
03-09-2012 11:22 AM
docsid
03-22-2011 12:14 PM
SykVSyx
North East
09-25-2010 02:07 AM
