Amp mounting.
Old 02-10-2009 | 06:42 PM
Azrael's Avatar
Default Amp mounting.
Ok on my old cars i have been able to mount my amps on the back of the seats but since my accord has less room on the seats and I have gotten a much bigger amp im thinking about mounting the amp on the side of the trunk area. I would just like some ideas on how to do this.
Old 02-10-2009 | 06:48 PM
t00fatt's Avatar
I have all my amps laying flat. You can mount them vertically but they won't stay as cool. The cooling is passive and designed to be flat, while there are some new digital amps coming out now that claim to produce so little heat they can be stacked. I guess those would be fine vertically, but other digital and switching amps should be mounted horizontally. If looks is more important than longevity of your amps then by all means, give it a go.
As for mounting it on the side, at least in a 7th gen, you would have to a bit of work to mount it up on the side. There isn't really anything there to secure it too.
Old 02-10-2009 | 06:53 PM
Azrael's Avatar
I wont mind mounting flat. I just was trying to think of how to hide my wires if I do.
Old 02-10-2009 | 07:01 PM
t00fatt's Avatar
I used those coil wire covers, you can get them where they sell home theater equipment.
Old 02-10-2009 | 07:16 PM
MacLeod's Avatar
Amps cool by radiating heat up thru their heat sink. If you mount an amp upside down it radiates its heat out upside down and since heat rises, it rises right back up into the amp and the amp overheats obviously.
Mounting an amp sideways will still let it cool although not as well as being flat but so long as youre not listening to it ***** to the wall all the time I doubt it would be an issue.
bellend
05-09-2012 10:56 PM
drumdoctor
01-16-2012 10:53 AM
adbraz
07-29-2005 04:24 PM
adbraz
07-06-2005 03:37 PM
adbraz
06-01-2005 01:46 AM
