Amped Speaker Question
Old 10-31-2011 | 02:17 AM
H0nda04's Avatar
Default Amped Speaker Question
Hi, I havent posted here in a while and since i have installed 6000k hids and blacked out the emblems but thats beside the point. I have Alpine SPR-69-C's on the rear deck and have Alpine SPR-50C 5-1/4" Type-R 2-Way Component speakers on the way for the front. The thing is that im running the stock headunit and i am underwealmed by the performance with the new speakers. I was of amping all the speakers but not adding a sub but was wondering if i could keep the stock headunit. Is there any way around getting a new headunit or would i have to to amp all the speakers. Also any suggestions for an amp? thing
Old 10-31-2011 | 09:30 AM
neophyte's Avatar
you dont have to replace the headunit. I am confused as to why you wouldnt amp all the speakers but no you dont have to.
this would be my suggestion on an amp.
MB Quart FX4.100 (fx4100) 800W RMS, 4-Channel Formula Amplifier
Old 10-31-2011 | 01:16 PM
H0nda04's Avatar
I would be amping all the speakers but how would I do that without replacing the factory headunit and running new speaker wire to all the speakers.
Old 10-31-2011 | 02:33 PM
crispin's Avatar
you need a LOC (line outoput converter)
It takes the speaker level output from your headunit and converts it to low levels RCA's that you can plug into your amp.
one like this
NEW RCA Car Line Converter Output Adapter HI LOW LEVEL | eBay
Old 10-31-2011 | 02:46 PM
keep_hope_alive's Avatar
Yes, amping the speakers is required if you want them to sound good. I prefer an amp with high level inputs and auto turn-on running from the stock head unit, compared to just running a new HU. But the amp install is much more involved.
Old 10-31-2011 | 02:55 PM
H0nda04's Avatar
So the loc takes the signal from the existing speakers and converts it to rca which then goes into the amp?
Old 10-31-2011 | 03:00 PM
Correct. You want the 4 channel LOC to provide a remote turn-on as well. A PAC model specific for your car is a good option. David Navone Engineering is another good option.
You intercept the factory speaker wiring and give the signal to the amp (all 4 channels), then wire from the amp to the speakers. There is a way to do this while using most of the factory wire, I can post a diagram later.
Old 10-31-2011 | 09:40 PM
H0nda04's Avatar
ok any specific suggestions for a loc and amp for my speaker setup?
Old 10-31-2011 | 10:43 PM
neophyte's Avatar
I suggested the mb quart amp. KHA may have another and he suggested the PAC specific for your car or a David Navone Engineering LOC.
Old 11-03-2011 | 07:50 AM
Mb quart lacks an auto turn on, and is just a Maxxonics product. Kicker, Phoenix Gold, Sundown can offer an auto turn-on and high level inputs.
