Best Speakers w/ Easiest Install?
#21
RE: Best Speakers w/ Easiest Install?
similar to his approach but a alot cheaper and i bit more ghetto
buy some standard size male slide connects. you will have to cut it down a bit to fit in the stock connectors though. i used a dremel. works great if you dont want to mess with your factory wires.
#27
Their Signature Reference line. Im using the SR5250's 5.25" component set. ThatsPolk's "high end" line. Theyre based off their $2000+ LSi home speaker line. The only things I dont like about them is the tweeters are too big and it makes it hard to squeeze them into some places. Plus they dont give you a surface mount adapter so you have to cut a 2" hole in whatever youre going to mount them to.
http://www.polkaudio.com/caraudio/products/sr5250/
#28
Hey MacLeod!!! I switched the polarity on my driver's side front door woofer and it sounds great! I couldn't believe that trick actually works! Now I have to re-solder the connections on my gf's since her doors have the Crutchfield speaker clips and I'd rather re-wire behind the head unit than take the door apart again. (She has an '01 LX ULEV sedan).
I have MB Quartz front components. The tweeter is a little smaller than the polks. I custom mounted them to the back of the grille. No dash cutting was necessary.
For everyone wondering about what fits well, I just installed my gf's JVC HDR1 head unit, iPod adapter (plug in the slot below the radio with the cover) and a set of Polk slim-fit 5.25's. The speakers fit in the stock brackets, but you have to cut the back of the basket off. I did this with a hacksaw and cleaned it up with a table grinder.
In closing, thanks MacLeod for suggesting to reverse the wiring on 1 front woofer!
