CHECK OUT! my Sick Zenesis alarm!
Until now I have tried DEI, CompuStar...
But... This one is the Kick ***
Check the video
http://s97.photobucket.com/albums/l216/tbo3366/?action=view&current=CIMG2194.flv
Check the video
RE: CHECK OUT! my Sick Zenesis alarm!
can it open or close windows? roof? I'd assume that it can pop the trunk. Does it come with relays or you have to add them on separate? Does it disable the starter by the key during auto-start? Will it set off the factory alarm when you auto-start if installed on a Honda? Does it disable the factory alarm or work in conjunction? Does it use the horn as well as the speaker?
And most importantly, why is this your first post here?
um...my bag doesnt need a string, ****!
its so big, it needs the support of a crane (or spoon, as shown in the pic) to remove it from wherever it may end up.
ok, that's enough about my bag
Thats an awesome alarm! How much does one of those run you?
And about the knocking (which is AWESOME) is the code set by the length between knocks, or was that a bunch of leds in a circle and you have to knock when it hits the ones you programmed it to?
The product is real, the poster is spam. I wouldn't trust a company that doesn't have a working webpage to look at the product details though.
http://www.clubxb.com/forums/f4/1501...ar-alarm-deal/
