Couple questions
So soldering is not one of my skills, can I crimp RCA's or does it HAVE to be soldered? Also, this will give me my voice guidance back correct? Also, is it best to start from the back of the hu or just splice into the speaker wire by the doors?
Best behind the HU. Minimize wire length,
There are some RCA connectors that use set screws instead of solder. MCM Electronics sells them. You just need to be very careful to now get a short.
There are other adapters that have male RCA plugs with speaker wires. Made to do just what you want,
Right, I did see something Radio Shack sells that is RCA on one end, and open wire on the other. So if I go behind the HU, am I connecting right into the harness, or splicing into the existing factory wires? Also, I know people say connect before the stock amp, is there even a stock amp or is it built into the navi?
This??
This??
#18
Ok, just ordered the harnesses. So being that I will be behind the HU, does it make sense to run wire from the HU to the sub amp instead of the way its currently connected, being spliced in from the rear speakers using the LOC?
#20
Gotcha.
So just to be clear, Im connecting these two harnesses together, one end goes to radio, other to factory harness. Where do I add the new speaker/rca cables? Where on the harness exactly do I connect them? I assume I have to disconnect the stock speaker wires as well, correct?
